hi i transfered all my tapes of a tv show onto my pc to make a dvd so i can wathc in my dvd player all the mpegs are aroudn 250 megs and there are 24 episodes is there any way i can make em all fit on one dvd or what..they are mpeg1 how many would it take and i can thave it in a lesser format im having trouble puttin vcd onto dvdr.
i would like to leave them mpeg1 as i am told they will fit onto a dvdr at 450mins .??>![]()
i cant follow the vcd onto dvdr tutorial.
there is a capacity of 4.8Gb on a normal DVD... All your episodes together are 6Gb...
Now, if you want them you'll have to buy a Double Side DVD Disk... they aren't too expensive anymore these daysWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
so i just split em up put em on two dsics and .. how do i make them vcd format on a dvd .. if i say i want to make a vcd in nero it sasy im using a cdr and wont reconize the dvd..
You must author and burn as DVD, you can NOT burn as vcd on dvdr.
If you change the audio to 48 khz should most dvd authoring tools be able to author the to standard dvds
www.vcdhelp.com/vcddvdr.htm
www.vcdhelp.com/author#dvd
www.vcdhelp.com/tools#burn -
ya, but the audio frequency should be the only thing he has to change... Only the audio on a DVD is different...
(forgive me if i'm wrong cuz, DVD stuff isn't really my domain)Wanne earn something a couple of dollars?
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
