I want a DVD recorder but have limited free space. How much room do I need to rip a DVD movie? I have about 8 gig free.
A normal DVD has a max capacity of 4.8 Gb... so i think ur 8GB's will be enuf
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Actually a single sided commercial DVD can be upto 9 Gb in size.Originally Posted by El Torro
some random guy. Waht is your target for the ripped DVD's. Are you going to make Divx's VCD's SVCD's or DVD-r. I suggest you take a look at the ripping guides listed on the left of this page. 8 Gb is just enough for some ripping methods, but for DVD to DVD-r you could do with much more, 12 - 15 is reccomended. HD's are cheap at the moment tho so that should help.
not enough room
By agent222 in forum Video ConversionReplies: 3Last Post: 9th Apr 2011, 12:16 -
connect pc to another room monitor
By blader18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Sep 2009, 15:19 -
monitor other room via web cam
By d_unbeliever in forum ComputerReplies: 1Last Post: 17th Apr 2008, 02:51 -
Anybody using SDTV and HDTV in same main/TV room?
By LT9000 in forum DVB / IPTVReplies: 33Last Post: 12th Sep 2007, 23:01 -
Chat Room Required
By Ryudo in forum Off topicReplies: 3Last Post: 21st Jun 2007, 08:35
