I was watching some MAC made SVCDs on my Pioneer DV-343 last night and it was working great. Then I tried to play a DVD and it won't do it. The display just blinks "Title" and it won't recognize the DVD.
I thought at first that since SVCDs are region free that somehow the auto software that detects regions got confused so I checked the region. It is the correct region. SVCDs still work but DVDs won't play.
Any ideas ?
-Squeed
VCD & SVCD Support For Mac
http://www.squeeds.com
i have the same player that also sometimes has weirdness ... ussually unpluging it for a minute , starting it up with a pressed dvd or FF it will cause it to work ...
I tried that but it didn't work.
-Squeed
http://www.squeeds.com -
do you have some compressed air and try to blow it out ?
i really dont think any other cleaners for dvd players really work other than blowing them out.
try dropping it about 20cm then with no disk in it flat on its feet (seriously)
did you try a varity of svcd's and vcd and then swapping back to dvd ?
i had this problem before but never sure what fixes it .. usssually i just do the drop and and unplug at same time ..
cures the noise sometimes also ..
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer DV-420V
By Vasilii in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Jun 2009, 08:28 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
