Hi everyone,
I occasionally use my computer as a VCR. Up til know I always convert my captured AVI's to VCD, burn them to a CD and then put it in my stationary DVD player to watch it in my livingroom (about 30 meters away from my PC). I would like to skip the convert/burn portion by watching the AVIs directly and then simply delete them afterwards.
Question1: Should I use the TV-out on my Geforce2MX video card and then transfer the picture by cable or air. OR Should I go for one more PC in my living room and connect it to the other one using a normal home network?
Question2: If I go for alternative one. How do I solve the keyboard and mouse issue?
Any feedback would be most appreciated. Maybe you can guide me to a good forum or webpage.
THANKS!
/Nicklas
Wireless network bandwidth is not sufficient for viewing films over a network connection. Maybe a 100Mbit network has enough bandwidth.
Extending video out might do the trick but 30 meters is quite a stretch.
Maybe you can install a PC in the living room. You can use a wireless keyboard and mouse like the ones Logitech sells. Equip this with a network interface to download the movie prior to viewing.
A more professional solution are boxes that convert TV signal to something that can be transported over network cabling. Some Hotels use this for an internal "cable TV" system.
Regards,
Willem
not enough room
By agent222 in forum Video ConversionReplies: 3Last Post: 9th Apr 2011, 13:16 -
Living without football (nfl + ncaa) withdrawal symptoms
By yoda313 in forum Off topicReplies: 3Last Post: 10th Jan 2011, 08:48 -
Living without flowing water
By johns0 in forum Off topicReplies: 8Last Post: 12th Dec 2009, 18:54 -
Bland picture after firewire transfer?
By Jazzy78910 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 31st Dec 2007, 07:10 -
Chat Room Required
By Ryudo in forum Off topicReplies: 3Last Post: 21st Jun 2007, 09:35
