  1. Anyone know what program is used to create Quicktime movies? if so is it shareware?
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Wow is that broad. Tons of programs can do that, including Quicktime itself.....you may wanna refine your question a little.
  3. oh right, I thought that there was one program like real producer that created quicktime movies. Could you recomend a good program to create quicktime movies?
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    How about Quicktime Pro.
  5. I've tried through quciktime player but it produced a small file and when I went to play it it was all mesed up, The picture was very blocky and the sound was stuttery
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Try using a different codec. Quicktime Supports a vast range of codecs that will effect the way your video looks. The same is true for the compression you run on your audio. Before you export in Quicktime Pro be sure to edit the Video and Audio settings to what you want.
  7. cheers for the advice will give it a go and let you know.
