Just got a copy of "The Sum of All Fears." After ripping to HD using smartripper, I tried to play it with PowerDVD, but got this message: "This player is not compatible with the region marking of this disc." The DVD will play from the actual disc using PowerDVD just fine. I re-ripped it with DVDDecryper and got the same result. I used the IFOEdit option to make it region free and that worked, but I've never had to do that before.
On what may be a related issue, I used the "split to 2 DVD's" option and after splitting, all they will play is the first Paramount screen, then PowerDVD stops. Any ideas?
MAke sure you did region free on all the ifo files this happens to me on a regular. Also make sure your save the ifo files after using the region free button.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
