My Sony DVD player flashed C:13:00 When ever I load in a miniDVD and press play. If I insert a real dvd, play it, then eject it. Then finally load the miniDVD and press play C:13:00 will flash, but DVD will light up on the player. So my player can not read a miniDVD, but does the C:13:00 mean anything bad?
Its probrably just an error code, see if you can find it in the manual
Ahh thanks, but I found it. C:13 means the disc is dirty and needs to be cleaned.
I suspect your Sony is not capable of playing miniDVD. Very few players support it. It's an un-official format and it seems very unlikely that Sony,who's firmware adhere's rigidly to specs would play it. If it does please post your model number.
As what wulf109 stated.
Furthermore, there is the likely possibility that your Sony DVD player (especially if it is an older model) doesn't like reading CD-R/W discs either...
You can do a simple test by burning an audio CD onto the same media type and seeing if that will play in your player.
Regards.Michael Tam
w: Morsels of Evidence
Flashing went wrong with my DVP5992/37
By chiquito3 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Apr 2010, 20:56 -
JVC DVD player flashing, otherwise dead
By lboiv001 in forum Media Center PC / MediaCentersReplies: 0Last Post: 9th Dec 2009, 02:13 -
Irritating problem (flashing vertical bars)
By weko in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2008, 07:40 -
Flashing Arrows To Emphasise
By Squid_uk in forum EditingReplies: 10Last Post: 13th Mar 2008, 23:17 -
VCR flashing messages converting too
By JustBeginning in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 16:39
