I am running Win98 SE so I have the 4GB limitation on File Size. The version of Vdub I have is 4.1.10. My object is to capture a multi-segmented avi file and then stitch it together using avisynth and just use the script to feed the avi's into TMPGEnc. All works well once the capture is done, but VirtualDub isn't segmenting my avi files and then I get some weird error message when the file exceeds the 4GB limit and of course the capture stops. The filename of the first "Segment" it captures is "CAPTURE.00.AVI" so I know it thinks its supposed to segment...There's a check mark next to the "Multisegmented Capture File" option in the Capture menu so obviously I'm missing something else.
FWIW, if people are interested I can post a guide on how to stitch the files together using avisynth; using this method I can feed more than 4GB worth of data to TMPGEnc without frameserving from Vdub.
CogoSWSDS
Results 1 to 1 of 1
cannot create i have a multi film menu
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Feb 2012, 16:22 -
how do i create a multi page root menu.
By visualhippocracy in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2011, 14:02 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 07:13 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01 -
What software to create a multi-title menu?
By ChrisPappas in forum Authoring (DVD)Replies: 1Last Post: 26th Nov 2007, 02:28
