No matter what I do, I get audio sync problems on VCD playback. I use TMPGENC to encode from avi to mpg, then VCDEasy and then burn with CDRWIN at 4X (that's the fastest my burner will go). I constantly get audio sync problems during playback. Who's got the master answer? I've been doing this for a year and still can't seem to get it right.
I am having the same problem but with DVD.
I too enc with TMPEG (avi 2 dvd) plays OK on pc.
Then I author with ULEAD MOVIE FACTORY.
I think the prolem is with ulead.DVD plays ok but go's out of sync.
Sorry I can't help
Kev. -
Not sure what you've already ruled out, but try to find out what is causing the loss of sync. In my experience it has never been tmpgenc.
- Is your source perfect? Quicktime MOV's and some avi's are able to play in sync on the computer even with drifting audio/video clocks and dropped frames, but tmpgenc or whatever your frameserving with may not be able to fix them enough to make a good VCD.
- Are you over-taxing whatever player you're using? If you are encoding at the bitrate limits of your DVD player or maxing out the CPU of your computer then audio sync will often fail.
If you are encoding a standard VCD with tmpgenc/vcdeasy/cdrwin (all great tools that I use myself) and you're seeing loss of sync, then it has got to be the source since just about anything can handle that format in stride.
<end>
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 08:10 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio Sync Problems
By mattr in forum MacReplies: 4Last Post: 7th Jul 2008, 09:55 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17
