Hi all,
Probably been posted before but I decided to build myself my own procedure based on the good info others have posted.
I don't know all the technicalities, and there may in-fact be a simpler method, but it works for me and is playable on PC or set-top player.
Ian.
How to create DVD-R/RW from VOB
1. Insert your DVD into the drive.
2. Make a dir called VIDEO_TS and run Decryptor. Point it towards the dir and rip the DVD.
3. Start IFOEDIT, and press the button [Create IFO].
4. You will be asked which VOB file you want to create VIDEO_TS.IFO, in this case navigate to the 1st VOB file of the set you just ripped. IFOEDIT will now scan and collects the IFO information and then will create 2 files VIDEO_TS.IFO and VTS_01_0.IFO
5. Now close down IFOEDIT without saving.
6. Start IFOEDIT and open VIDEO_TS.IFO and click on [GET VTS SECTOR] and follow the suggestion until finish repeat this step with all IFO files in this directory. Close down IFOEDIT and again without saving.
Now burn the files to DVD-R/RW using Nero, you must use the DVD-UDF/ISO and uncheck the Joliet option i.e. the last option on the wizard.
Burn to a dir called VIDEO_TS, you may want to create another folder AUDIO_TS although, this is not necessary.
How to split a dual layer DVD title to two separate single layer DVD-R/RW from VOB
7. Continuing on from above (steps 1 to 6 above – without the burn!). Prepare two empty directories and name them DVD1 and DVD2. Within each of these directories, create a directory called 'VIDEO_TS'.
8. Start IFOEDIT and load the IFO of the main movie, i.e VTS_01_0.IFO.
9. Press the button [VOB Extras] . A dialog box will appear, allowing you to select what processes you want to do. The standard options are already selected for you.
Select the [Strip Streams] option also. DO not select [Strip VOB ID’s].
10. Down at the bottom, select the DVD1 and DVD2 directories you created.
Press the [OK] button.
11. A dialog box will be displayed containing the chapters. Pick a single chapter somewhere in the middle of the table, press [Split It].
12. Another dialog box will be displayed containing the Audio Info. The two default selections are ok, press the [Strip It] button.
There will 2 separate DVD rips, treat them as two separate movies.
Home built:-
1.2GHz Athlon / 384mb ram / Full tower
AIW 8500DV
60gb & 120gb HD
Pioneer DVD- Writer, CDRW drives
Turtle Beach Santa Cruz soundcard -
yes this has been discussed before but anyways.. just to comment on the first part of ur "How to"..
Decryptor automatically creates the VIDEO_TS folder inside the name of the DVD movie(did i say it right?) i.e. x:\<Movie name>\VIDEO_TS
Second i think creating the AUDIO_TS folder is important as it is part of the standards when creating a compliant DVD..
:^)I FEAR NO BEER!!!
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
duel layer to single layer question
By joelw_7 in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jan 2008, 02:25 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 11:48 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
