I have recently installed a dvd rom on my aunts computer, after installation it showed the drive in my computer but every now and again when i go into my computer it does not see it, but it does play what it should.
Any ideas on why it keeps dissapearing from my computer.
OPERATING SYSTEM WINDOWS XP
PROCESSOR INTEL CELRON
For clarification is your aunts computer and my computer the same computer or are hers and yours hooked together?Originally Posted by karlfradley
Make sure you are using latest SP1 for your XP, and also Latest IDE drivers for your mainboard, and lastly, make sure the cables are connected properly and that they are 100% operational.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Although that is most likely, I suggest you first try installing the SP1 and IDE drivers, and that might fix your problem.
Although personaly I still use 98, and I don't have half the problems others with XP and 2000 are having.Email me for faster replies!
Best Regards,
Sefy Levy,
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 12:54 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 11:49 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 09:19 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03
