    Jul 2002
    New Mexico
    When converting from video captured at 704 x 480 to SVCD in TMPGEnc, the picture is distorted (stretched horizontally) when played on standalone player. VCDs turn out OK. I must've screwed up a setting somewhere. Any Ideas?
  2. Make sure you use the "Full Screen (keep aspect ratio 2)" settings, this will
    fix any distortion you might be having right now.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Jul 2002
    New Mexico
    Thanks, I had tried "Full Screen" and "Full screen (keep aspect ratio)". I'm glad I didn't have to work my way down the list.
  4. You haven't mentioned if your problem was solved
    Best Regards,
    Sefy Levy,
  5. i think u solved it m8, good work
  6. Oh, in that case, i'm glad to have been of help to you!
    Best Regards,
    Sefy Levy,
