hI! just need to know one thing before i buy a dvdwriter for my PC! if i use nero or any other writer app, can i move a divx file over to write then view it in my dvd player! basically what i'm saying is do i have to convert the divx file through the app before writing or can i just write the divx file on a dvd disc then play?? The way i see it is what evers on a DVD disc from video to audio can be played in a dvd player but i could be wrong so please help.
laters
Results 1 to 22 of 22
Yes you could, although I don't know why you want to waste a DVDR on a DivX movie.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
thanks for the reply so all i have to do is use nero and go to cd-ROM(iso) option and drag the divx file then just write on the disc! NO CONVERSION included??
When burning a VCD/SVCD Nero does the conversion for you when dropping in a non-standard file..Originally Posted by master2004
however, why would you select cd-rom if your burning a DVD?
i dont have a DVD writer, but i dont think Nero will do the conversion from AVI to DVD format like it would for VCD -
When you say dvd player, are you referring to the one in your computer or a standalone dvd player?
If you concerned with quality dont let Nero encode anything - it will suck.Originally Posted by johneboy
get cce or tmpgenc -
cant argue that...Originally Posted by SLBOSS926
however.. converting a DivX movie to a DVD isnt going to be the best idea (quality wise) anyway -
i meant a standalone dvd player! this is the thing guys i didn't really wanna convert the file in any way. all i'm saying is basically a standalone dvd player plays dvd-r's right!! so in that case if i have a divx file on a DVD DISC i would expect it to play it because its on a DVD DISC! also not forgetting DIVX FORMAT IS A MEDIA FILE aswell so thats why i need to know if it works.
No it must be a mpeg compliant file,
unless your going to get the new kiss dvd player that can play divx also -
there is one DVD player thats coming out soon from a company called KISS that will play DivX files
http://biz.yahoo.com/iw/021022/047810.html -
ok then! when u use vcd option on nero if i drag the divx file over how long would it take to encode the file to DAT' or mpeg before writing the file
That would all depend on the speed of your computerOriginally Posted by master2004
my 500Mhz AMD (dont laugh
) takes a long time, so i generally just do it before going to bed, when i wake up, its done
so if i had a dvdrip movie in divx format and did the encoding with nero what would the quality be like when done??
DivX is already a compressed format, and as SLBOSS926 stated above, the encoder in Nero sucks. Which i will agree with.Originally Posted by master2004
Nero would be the most simple solution, but if you want to squeeze as much quality out as you can, try encoding it with TMPGenc -
open TMPGencOriginally Posted by master2004
drop in the DivX file
hit the load button
select the VCD template (not sure of the actual file name, not at home now)
then hit start 8) -
Look master2004,
Why don't you start reading here:
http://www.vcdhelp.com/tmpgenc.htm
That way you might be able to help somebody else in the future not just be spoonfed by others.
Regards. -
thanks guys iight!
one more thing
if i get a 2x dvd writer how long would it take to copy about 1GB?? and aslo a complete 4.7GB dvd disc ?? thanx
Hi, guys, i need help with my picture dvd...thanks!
By Lady Colour in forum Authoring (DVD)Replies: 11Last Post: 22nd Dec 2010, 10:46 -
Can you guys brighten my video please? ^__^
By Jenniilovekpop in forum RestorationReplies: 1Last Post: 24th Nov 2010, 16:50 -
help guys. out of sync mp4.
By tryvora in forum Video ConversionReplies: 2Last Post: 26th Dec 2008, 10:54 -
Can you guys look at my commercial?
By dogmaratt in forum Off topicReplies: 10Last Post: 17th Feb 2008, 10:42 -
Ok Guys, I need some advice on AVI?
By Soccerman77 in forum Video ConversionReplies: 5Last Post: 25th Nov 2007, 23:39
