I have some avi files on my pc and when i try to open them i get this error message "Couldn't open the file "movie.avi" because the end of file was reached prematurely" whats wrong with it i have 3 avi's that are saying that!!!!
Results 1 to 15 of 15
Sounds like those AVI files are either bad, or were not downloaded properly
you should either re-download, or try opening them in VirtualDub to run a fixEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
You can get VirtualDub from www.virtualdub.org
I might also suggest you try getting Kristal Studio Codec PackEmail me for faster replies!
Best Regards,
Sefy Levy,
Try the Tools section, or try www.digital-digest.com
Best Regards,
Sefy Levy,
ive got virtual dub and ive tryed to open it and it gives me this "Couldn't locate decompressor for format 'DX50'
Then you just need to download DivX 5.02 and install it, it's located here if i'm not mistaken www.divx.com
Best Regards,
Sefy Levy,
Re-Download and Re-Install it, taht error message you mentioned says you don't have DivX 5.0 installed on your system, which is why it gave you that error
Best Regards,
Sefy Levy,
Glad to be of help!
Best Regards,
Sefy Levy,
argh one more problem
ive got
men in black 2 cd1
men in black 2 cd2
and Triple x cd2
and once loaded they play exactly the same trailer
why
Acrobat Pro X not opening files within an IE window
By Toastie in forum ComputerReplies: 1Last Post: 22nd May 2011, 13:49 -
Opening video files from computer
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 17:55 -
Opening files in Graph Edit
By tb582 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 13:27 -
Opening Multiple files in Dr. Divx
By clawg in forum Video ConversionReplies: 0Last Post: 8th Apr 2008, 13:04 -
opening .z files on a mac?
By jwnulife in forum MacReplies: 1Last Post: 20th Mar 2008, 09:53
Where do i get the program from???
