I am attempting to capture Video from old tapes and burn them to DVD+RW disks. Got it working but the quality was quite low so I started improving it. I am now using the AverTV card with Virtualdub to capture. This allows me to greatly improve the quality of the AVI. Then I go to TMPGEnc to convert to mpeg, edit the video, then demux to create .m2v and .ac3 files. Then I use ifoEdit to create VOBs for the DVD.
So far so good and my simple tests show nice videos and sound.
Then the problem. I go to Nero to burn and get an error message:
"File size not a multiple of a logical block size"
"Files Realocation Failed"
I have search the foum and the internet and only see references to people having this problem when they attempt to burn to 2 disks and possibly related to editing the content. I am doing something wrong with TMGEnc when I cut the beginning and end of the video?
Thanks for the help.
Chris
I got the same message and burning was hot or miss ( I used dvd-rw's ). I ended up using DVD workshop to burn my title set without problems.
All I did was take 1 mpeg-2 ( dvd compliant ) use ifoedit or spruceup to create the title set and then attempted to burn with Nero, like I said 50/50.
Sounds like about what I did. So far I'm at miss-miss-miss. I'd be happy if 50/50 worked. Someone must know the answer.
Chris -
When burning with Nero, use UDF/ISO mode rather than DVD-Video. This should fix it.
I did that already and it didn't help any. I saw how that helped folks who split movies on 2 disks, but it didn't do anything for me.
Thanks for the idea anyhow.
Chris
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
"DVD-Video files reallocation failed"
By alegator in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2008, 10:26 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 12:20 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 06:59 -
DVD-video files reallocation failed
By Sean_ve99 in forum DVD RippingReplies: 3Last Post: 23rd May 2007, 18:44
