hey.
yeah so i am having problems trying to encode a 25 fps avi clip to mpeg1 or mpeg2 using TMGEnc. i know i need to select PAL. but everytime set everything up and i go to preview it gives me weird resolution, like 480x520 or something like that. and i know that i am supposed to select the "full screen (keep aspect ratio)" setting selected. i don't know what to do. i have tried to do some things but nothing seems to be working. can some one help me?
And are you closing the wizard and manually selecting the templates with the Load function?
Hello. -
PAL SVCD is 480 * 576. TmpGenc preview mode does not display this correctly, nor does WMP. Encode a small section then preview it with a soft DVD player in file mode like WinDVd or Power DVD to see wether it is correct.
you could try this: http://www.vcdhelp.com/forum/viewtopic.php?t=119210
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 04:30 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 04:42
