Is there a way to make FFMPEGX able to encode a VOB with a Variable framerate. I just bought a new DVD(National Lampoons European Vacation) and it has a variable framerate. Could someone tell me how to make my vob to vcd with the variable fremerate, OR could Major add in another feature on FFMPEGX 0.4d. Thanks
Qshartle
Results 1 to 15 of 15
"Good Luck 007"
In Memory of Desmond Llewelyn
im going to make the guess that hes sayin its a variable frame rate video, and from what i have discerned ffmepgx doesnt do well with ones that are really severe- thas why i encode the mpeg-2->mpeg-2 in QT or mpeg-2->DV in QT because they are the only ways i've found to get a source file with variable frame rate to a constant 29.97, after that i run it through ffmpegx or mediapipe/mediapowertool to get it to vcd or svcd.
bilestyle
I understand QT is the best (only) decoder that handles variable in, with constaint out. Though Makira is real close to duplicating that.
Is the output of mpeg2enc in either ffmpegX or MediaPipe variable frame rate? If set to ntsc 29.97 output? If set to ntsc 29.97 pulldown output?
Three answers required.
RNC
Originally Posted by Ross
hopefully that site can help a little bit more than i can.
major---
i have to ask you, how did you script to get qt to decode the video? qt wont decode this video unless you trick it by adding the black frame before using to to decode/encode to mpeg-2...i think that trick worked properly, but i forgot to remove some of the post processing options so it deleted my output file, but when i previewed it at the finish it was the proper length.. ingenious idea... that will actually make it so i can do the full process in ffmpegx instead of my much longer ways... thanks for the tipkeep up the good work.
There is code in ffmpegX calling the Quicktime carbon routines to decode when the filename ends in ".mov" (only when target format is MPEG-2, but I'll extend this to other formats soon). If you export the sound to WAV with the same name and in the same folder before starting the video encoding, ffmpegX will also pick it automatically and mux with the video to make a SVCD.
yeh i added the keep elementary streams and echoed to the command line to see what u sent to movtoy4m to better understand what happens.. its crazy that JUST adding the .mov to the end of a vob file will allow movtoy4m to pipe the output to mpeg2enc -- so it appears the problem must be fixed BEFORE it hits mpeg2enc to get a framerate to be stabilized at 29.97 or 25... very interesting..... i'll definitely have to use this idea/concept when working in new ideas to mediapowertool... thanks alot major great work.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 08:44 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Canon EOS movie: variable framerate problem
By jullebarge in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 17:54 -
Variable FRAMErate dvd demuxing
By gbi in forum Video ConversionReplies: 8Last Post: 11th May 2009, 07:24
