Would someone please explain YUV, YUY2, UYVY ..etc This keeps coming up and I can't seem to find a good answer in the search engine. Thanks.
rhuala
The Y's represent luminence ( b&w ) information an U and V represent color information. YUV would be 24 bit per pixel capturing at 4:4:4 ( ie color samples every pixel. UYVY, YUY2 and similar are 4:2:2 or 16bit since you have 8 bits of b&w + 8 bits of one color ( alternativg ) for every pixel.
YUY2 and UYUV are probably the best for capturing since they are the closest representation to the original signal that is availible.
DV is 4:1:1 so color is only sampled once for every 2x2 block of luminece, this is why you can often see color blocks when viewing DV materal on a monitor. -
Well that's as clear as mud, I understood bits of what you said but I really don't see where the 4:4:4 numbers fits into all this this. I though YUY2 and UYVY have 16 bits/pixel and RGB24 has 24 bits/pixel, but is this just a standard or can u derive this relation ship from the actual letters?
i.e.
Y =8 bits of luminence
U and V=8 bits of color (8+8=16)
so YUV=8+8+8=24 bits of info describing a video... sorry I don't get it...
"DV is 4:1:1 so color is only sampled once for every 2x2 block of luminece" ... missed all of this statment could you please explain 4:1:1, 4:2:2, 4:4:4?
Is there a tutoral on this or a table that breaks down the comparison, I appreciate your attempt in trying to explain this, I really do, but I just started getting into this last weekend and don't have the fundamentals to understand your explanation... sorry.
Thanks,
rhuala
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 11:21 -
How to take stream in -> decode to file (UYVY)
By zakeboy in forum Video Streaming DownloadingReplies: 5Last Post: 28th Aug 2009, 14:30 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:07 -
uyvy video format
By joshalb in forum MacReplies: 3Last Post: 22nd Oct 2008, 15:28 -
YUY2 Vs. UYVY Capture
By W_Eagle in forum Capturing and VCRReplies: 2Last Post: 11th Jul 2008, 11:15
