The problem is that CDRWIN doesnt find my cd writer...
I installed the ASPI and check it out in the aspichk and everything was fine.
Then I launch the prog, there were no error crying about cant find the ASPI, but when I push on the button "Write CD" in the upper left of the prog, a message pop up that says "Cant find cd writer on SCSI or on IDE bus" or something like that.
I checked the option in the ASPI tub in the option that says "Use ASPI drivers from the sytem defualts" but it still didnt help, any Idea anyone?
I'm using CDRWIN 4.0A.
did you select the writer from the pulldown menu toward the top of the working area?
When I say "The problem is that CDRWIN cant find my cd writer..." I mean that my writer does not apper in the pulldown menu but thank you for trying to help.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
