Hi,
I'm using smart ripper 2.34 and the speed I'm getting is
3 to 4x, but I have a Pentium 4/WIN98 SE, and a Panasonic
16x DVD drive. Is there some option I can change to make it
faster? Thanks!
Way
Sure, follow these steps...
1. Get Win2k emediately, and microwave your win98 CD (it makes a nice light show)
2. Once you have win2k, you should then enable DMA access to your DVD-ROM. Right-click My Computer and choose "Properties". go to the Hardware tab, then press "Device Manager". Determine which IDE channel your DVD-ROM is on, and expand the IDE ATA/ATAPI controllers. Double click the IDE channel your DVD-ROM is on and go to the Advanced Settings tab. Enable "DMA if available" for your DVD-ROM. (This can be done in win98 in a similar way: find your way to the Device Manager in My Computer Properties and double click your DVD-ROM. Go to the settings tab and check DMA.)
3. Try changing the settings related to VOB file access. the default is ASPI (1 GB files), try changing it to normal or aspi.
4. Ripping speed will increase as you near the edge of the disc beacause there is more data passing the laser per second as you move out from the center of the disc.
5. Did I mention that win98 is a POS and you should only use win2k? Good, I did. -
I have an idea, search before you post.
Now go here, to a thread that was already started.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=51768&forum=11&27
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 22:12 -
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 16:00 -
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 12:52 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
