i get this error after some time encoding:
"AVIsource: failed to decompress frame 81462 (error -100)"
the screen is all black.
what is this and how do i solve it!?
-d-
If you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello. -
ok...but i dont think that this is it... i have no problems encoding, lets say the first half of the movie, but then this error comes!
i´ve encoded several xvids, avis divx´s before without problem...
and the movie runs perfectly when i play it in WMP for example...
i´m confused...-d- -
its a bad frame -- do a search on removing bad frames with v-dub here ... there is a guide posted
ok.. but i dont understand... u can divide everything with 8... what´s the best size to have... =what should i resize it to?
second... the file gets lage as hell and the sound is crackling.
damn!
what should i do?-d-
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 20:30 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
