Are the Mpeg 2 encoders in MMT (mediapipe) and ffmpegX mpeg2enc the same thing. If they are different? Which one is better quality at say producing SVCD mpeg 2 video.
They both use the same mpeg2enc module from the mjpegTools project by Linux Square. If transcoding mpeg to mpeg, they use different mpeg decoders. This does makes a difference.
Ok....
Ross or anyone with the knowledge to answer. Which one has the best Mpeg2 decoder. That is which program produces the best DVD to SVCD rip?
Second Question. Do they have the same decoder for .mov (QT) files? I also want to convert DV to SVCD (I don't have a DVD burner yet so have to put up with what I have) and was wondering what package does this the best. MMT seems to have more settings. -
If you want to go from DV to MPEG-2, I find that Apples own codecs actually give the (by far!) best result. Unbelievably crisp and fast - even at low bitrates. You need an altivec g4 though.
"I have not failed. I have only learned what does not work."
-Edison
what is the difference between PCM & MP3
By ashe09 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2012, 08:50 -
Hdmi Difference Between Silver & Gold?
By ofield1 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Mar 2008, 17:07 -
Dealing With DVD Rebuilder: Encoders & Settings to Get Nice Results
By devilcoelhodog in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 22:55 -
What's the difference in quality between SP & LP modes in MiniDV??
By navi310 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jun 2007, 12:09 -
Difference between DirectShowSource & aviSource?
By romi7519 in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2007, 13:18
