Well I received my LF-D311 yesterday and ran into some problems, maybe someone might be able to give me some advice.
I installed the drive and install the XP Drivers from the installation disk. Everything went well until I tried to play my DVD-R disks, I had no sound. All the connections are correct but for some reason I get no audio. If I put a music cd in the drive it plays fine. All wave files on my system play fine as well.
I decided to try store bought DVD's and got the same results (no sound). I did notice one strange thing. I took a DVD-Ram disk that was created with my DMR-E30 and tried it and it played fine with sound, but if I tried to play that same dvd-ram disk using the explorer and clicking only on the *.vro file I got no sound. Yet if I tell PowerDVD XP to play the disk letter then it played fine.
What gives, I have no idea why the disks have no sound unless it's a DVD-ram being played straight from the disk drive icon.
I would appreciate your help,
Ernest
That's a software and Win XP setup issue. Nothing to do with the drive.
I suggest you check your settinsg. -
Do you think I might have to reinstall the XP operating system? I checked the control panel options under audio devices and saw nothing unusual.
Do you have any recommendations as to any other areas to look at?
Thanks again,
Ernest
I think I found the problem but still no solution.
It seems my computer can't play any video created with Dolby Digital.
I tried using a VCD and it played fine, I also used tried audio CDs and they played fine also. It seems that I might need a codec or drivers that will enable my computer to read DVD-rs and Store bought DVDs.
Do you have any idea what those drivers might be?
Thanks EJ
Panasonic LS83 sound
By wraeththu in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Aug 2011, 16:19 -
Panasonic DMR-EA18 recording help needed. No sound in video playback.
By LegendaryGamer in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2010, 08:52 -
Panasonic GS-250 taped race has area of no picture but sound
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2010, 04:32 -
Panasonic E25S dvd recorder sometimes no sound, sometimes the language is
By padraig in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th May 2010, 19:18 -
Help, no sound from Panasonic DMP-BD35
By colt4523 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Dec 2008, 20:45
