I downloaded a Divx file and followed all of the instructions here http://www.vcdhelp.com/divxtovcd.htm#audio to make it a VCD. The only error I had was at the end when I was burning it with VCD easy, but i looked up the problems section and it said select a Force driver so I did and everything worked fine. I can play the video on my computer, but I went to play it on a stand alone DVD player and it popped the disc back out and said disc error. Does it matter what type of CD-R you use, or is it just the DVD player?
It would help to know what the DVD player was
It sounds like your player wasn't designed for CD-R or CD-RW media.
Try burning an audio CD on the same blanks. Do they play properly?
If you not, you will have to try experimenting with different brands of CD-R/W media. In these cases, CD-RW often works better.
Regards.Michael Tam
w: Morsels of Evidence
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 24th Aug 2011, 23:26 -
some .mkv won't play
By snooze091 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 17:48 -
MP4 won't play
By lilblu in forum Software PlayingReplies: 3Last Post: 14th May 2009, 23:25 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 15:20 -
DVD won't play
By Golgo13 in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2007, 15:40
