Hi. I am hoping that someone might be able to clarify something for me. I am capturing from VHS via a Sony camcorder (using Scenalyzer Live to capture) and opening the captured video in Virtual Dub 1.4.10 via an Avisynth script using the MainConcept DV codec. Finally, I am frameserving this into TMPGEnc with the intent on creating a standard SVCD file. Everything appears to be in order, but one oddity I am noticing is that when I open the frameserve.vdr.avi file in TMPGEnc, the Encode and Video Source Fields are set to non-interlaced, when I know that the source .avi is interlaced. If I open the .avi instead of the frameserved file, it indeed sets it to interlaced. Does anyone know why this happens? I have encoded a few test SVCD's and they appear to be ok, but before I begin converting a stack of VHS tapes, I just wanted to make sure that all is right from the get-go.
Thank you very much in advance for your consideration!
Just make sure you settings match your source, and you'll be fine.
Impossible to see the future is. The Dark Side clouds everything...
TMPGenc 4.0 XPress Question
By spliffy in forum Video ConversionReplies: 1Last Post: 19th Oct 2009, 17:04 -
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 19:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38
