  1. I rip movies using SmartRipper and use DVD2AVI to frameserve to TMEGEnc to make XVCD's.
    Is there any way I can insert subtitles using the method I've already established and gotten used to? Maybe some AVISynth plugin like MPEG2DEC (as an example) or something? Or a way to insert the subtitles to the .mpg files afterwards?
  2. http://www.doom9.org/index.html?/subtitle_guide.htm
    otherwise, you can replace dvd2avi with flaskmpeg as the frameserver and add subtitles this way...there are less proggies to use if u use flaskmpeg.
    http://www.vcdhelp.com/dvdtovcdflask.htm
