i was in need of some help regarding adding subtitles. the guides are great and were easy to follow so my thanks and appreciation to those who created them. alright, i wanted to make a copy of a foreign movie with the subtitles on it. so this is what i did:
1) used 'smartripper 2.41' to get the vob's
2) used 'subrip 1.10' to get the srt's
3) used 'srt to ssa converter' to get the ssa's
4) then opened 'virtualdub 1.4.10' setup the filter 'subtitler', then finally setup the 'start frame server'. and i save the file "anything.vdr"
5)then i open up 'tmpge 2.58.44.152" so i can encode my mpg movie. however when i try to open "anything.vdr", an error comes up. the error "can not open or unsupported" pops up.
why is this happening. i thought i set everything up good. any help would be great.
Vim
Results 1 to 9 of 9
here it is:
http://www.vcdhelp.com/subsvirtual.htm
any help would be appreciated -
How you get the SRT with subrip? I can't seem to get it with subrip.
what format do you get?
i followed this guide here
look here:
http://www.vcdhelp.com/srtsubsvirtual.htm -
I'm following this guide here.. http://www.vcdhelp.com/subsvirtual.htm i'm on the step where is saids ...File->Open and open the Video what video do i need to open? the .vob?
This is the part that confuses me. in the example is says the file named .vdr. so im unsure of what to use. does anyone experienced with this have an idea on what to use?
if no one comments, im just going to this guide:
http://nickyguides.digital-digest.com/subtitles.htm
im not sure, but i think this method allows you to turn them on and off. but im not sure -
tablaboy,
your problem with frameserving from vDub to TMPGenc (& the .vdr file) is quite a common one.
have a look at this thread, and the threads & guides it links to.
http://www.vcdhelp.com/forum/viewtopic.php?t=107096
' hope that helps,
mcdruid. -
Hey tablboy, on step 2, when you finish typing all the letters in with subrip, how do you save it to get the srt?Originally Posted by tablaboy
ConvertXtoDVD subtitle issue.
By Randwill in forum SubtitleReplies: 3Last Post: 7th Sep 2011, 11:01 -
subtitle issue when re-encoding..
By tsh in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 01:26 -
Subtitle issue
By Mrsash in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2010, 20:43 -
Subtitle issue
By eppingwest in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Feb 2009, 13:35 -
Subtitle issue with DVDAuthorGUI
By GangstaRap in forum Authoring (DVD)Replies: 1Last Post: 11th Feb 2008, 07:37
