Hello, I'm having a problem burning a japanese anime. Whenever I wanna burn a DVD i have to play movie first, then I can start copying the DVD ie through smart ripper, or Clad. Since I'm trying to copy a foreign film, I can't initially play it on my comp, so I can't copy it. Is there any way around this? Or is there a program that will change the country code on my comp with out my comp noticing the change? I've already changed the country code on my comp enough times where i can't change it any more. And DVD Genie isnt working for me. Please respond if you have any ideas. Thank you.
It could be that your DVD-ROM drive is "hard wired" for your region,as mine was. My Creative drive required me to flash the firmware with a modded version to remove region restrictions.
Tool Man. -
use Dvd decrypter, it can rip mismatched regions.
It'll use Brute Force and DeCSS instead of I/O Key and VobDec. -
See this website in order to see if they have a region free firmware for your DVD-ROM player. You must also download a freeware program called DVD Region Killer (a better program than DVD Genie under Windows XP). Thiese steps should allow you to play DVDs from any Region.
http://perso.club-internet.fr/farzeno/firmware/
Be sure to know exactly what you are doing before proceeding as changing firmware can destroy your DVD-ROM player, if it is not done properly.
Can't Copy Foreign DVDs
By Mark-Leon in forum MacReplies: 50Last Post: 9th Nov 2010, 13:33 -
Ripping dvd without foreign muxed into vobs?
By Davross23 in forum DVD RippingReplies: 1Last Post: 4th Sep 2010, 09:43 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Transfer foreign language DVD's to phone, Nokia N82, keeping SUBTITLES
By dohouch in forum Portable VideoReplies: 1Last Post: 3rd Feb 2008, 07:19 -
Foreign DVD plays on computer but not on DVD player
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 23:28
