Maybe I posted in wrong area before, but doesn anyone know how to do the following in Adobe Premier 6.5:
1. Food compressed saving! If I capture a nice long .avi file using say the Morgan Media Codec I am having problems saving after I edit and crop the file. If I export as a MPEG2 file for SVCD burning (tried all kind of settings, various VBR's .. etc) the finished file pales in comparison to the same file encoded with TMGEnc. Has someone found good settings for this?
If I edit the original capture .avi then save it as a native .avi file then use TMGEnc, it still doesn't look great because Premier has re-encoded it losing the quality from the original Morgan Codec compression.
So how can I take my clean edited captured .avi file and convert it to a nice SVCD mpeg2 file?
2. Is there a good forum dedicated to Adobe Premier?
3. Are there good online tutorials for Adobe Premier (beyond the manuals)? Google pops up a few but the more the merrier...
rhuala
Results 1 to 1 of 1
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 11:24 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 23:01 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 22:55 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 11:29
