Im usig avi2svcd (dvd2svcd)...
i want to make a svcd of a avi-file that i´ve downloaded... its a XVID, but it has not been a problem before... when i try to do this i get this messege from tmpgenc.:
"The resolution of the video is illegal.
>The window size needs to be set between 8x8 and 4088x4088.
>The with and height of window needs to be multiple of 8."
WHAT THE F**K DOES THIS MEAN... how do i solve this problem...
i don´t want to use just tmpgenc to create a mpg, i want the image-files (bin´s & cue´s) that avi2svcd creats....
is there some other way to create image-files from avi´s than this way??
PLEASE HELP!!
-d-
It means that your Horizontal or Vertical (or both) resolution isn't a multiple of 8 (can't be divided by 8 ) which isn't a legal resolution. You need to resize your resolution (one way to do this is to add black borders) to the next legal size.
ok i hear you...
but how and where do i do this... is it in avi2svcd or what...?-d- -
With Virtual Dub:
1) File->Open video file..., select your AVI, Open
2) Video->Filters..., press ADD, select resize, press OK
3) Type in the New width and New Height (must be a multiple of 8 ), in the Filter mode box select Precise bicubic, press OK, press OK again
4) Select Direct Stream Copy under Audio and Full Processing Mode under Video, go to File->Save as AVI..., type in a new name for your AVI, press SAVE.
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
