What do you recomend for the setting Min Max and AVR??????
well.....Originally Posted by Mike229
2 things:
--are we supposed to read your mind as far as how long your movie is, how many discs you're planning to use, and what type of file your creating(VCD, SVCD...)
--have you tried the bitrate calculator?
http://www.vcdhelp.com/calc.htmwhat are you askin' me for...
I'm an idiot! -
To calcualte...
Min = 1/3 average OR the minimum your DVD player allows
Avg = target bitrate based on media size and length of movie ( at least several hundred smaller than max )
Max = Double average OR the max the format allows ( svcd = 2500 ) -
Cheers snowman. Thats all i wanted a roughf idea. Where can i find out my dvd player bitrate limits. With out the trile and error bit!
Me again! Motion search should i leave alone or does it make a lot of diffrence!
Check the DVD player list and ALL comments for special items like minimum bitrate.
I ususal use high. -
Motion search precision DEFINATELY makes a huge amount of difference!!!
Bitrate definately does too.
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 14th Jul 2007, 23:24 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
