k, its one of those days i'm nearly going mental. i try to frameserve from VD to CCE. it used to work like a charm under winxp but now, after i've used tmpgenc for a while, it doesnt at all. i tried CCE 2.50 and all 2.6x i have. it used to work on 2.50 now it says, "AVIFileOpen.....unknown error". so i thoought i try this link2 stuff, but that just says "unable to open file. are you forcing your AVI to unsupported format".
i do have the avihandler installed from the VD directory, i checked the 2 files are in the \system directory. i guess the reg entries are made correctly as well.
using winxp sp1. intel p4....and as said, tried all CCE versions.
what am i doing wrong? what should i do?
btw, if anyone knows another way to frameserv to CCE that doesnt involve me having to do scripting all the time, pls shout.
Results 1 to 9 of 9
Ok their are a few items...
1) Only CCE 2.5 and CCR 2.66.xx can open frameserved files
2) VDub 1.4.10 has a frameserving bug you need a particualr file in your system directory msvcr70?? i think it's the .net runtime.
3) Have you installed the handler using auxsetup? -
i never heard about the msvcr70.dll thing - interisting ..
anyway its part of the Microsoft (R) C Runtime Library, v. 7.00.9064.0
and you can get it here: http://www.dll-files.com/dllindex/dll-files.shtml?msvcr70 -
XP .NET Cure for missing msvcr70.dll and mscoree.dll
Many users who install the current build of the Microsoft.Net SDK complain that the C# compiler does not work and C# executables will not run. Error messages note that msvcr70.dll and mscoree.dll, respectively, are missing from their system directories.
Here is the cure. Uninstall the samples and the sdk. Then restart the computer in safe mode. These are several ways to do this. The old way still works: hold down the F8 key during startup until the computer starts beeping. You will be presented with a list, select 3 - Safe Mode. If instead you see the desktop, you waited too long, try again.
Browse to the big Setup.exe file that contains the sdk. Reinstall the Microsoft.Net SDK.
The files msvcr70.dll and mscoree.dll are now in your system folder.
Restart the computer in Normal mode. The csc.exe compiler will work, and c# exe's will run. -
1.4.10 was built with the .net installed and it linked ( by accident ) to the runtime. It is completly unessary for the opertion of vdub 1.4.10, but it has to be there or it will complain.
Avery plans on fixing it in the next binary release. -
maybe thats what happened to Matrox .. we have to install NET runtime first before we can install Matrox powerdesk and drivers for the Parhelia .. which makes not a lot of sense and i didnt really want to ..
aaargggggggghhh! thanks but i had that dll already in the systems directory and i used 1.4.7 VD anyway. help! there must be something else wrong. right about now, i hate this crap.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
Link2?
By iThinkYouBrokeIt in forum Video ConversionReplies: 4Last Post: 5th Nov 2007, 23:14 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
