The entire message when staring up Maestro which I just got and installed on XP Pro yesterday is "No encoders were found so you will not be able to use realtime preview." I know I WANT to have realtime preview. Do I need to download some kind of encoder pack or is there some kind of file in DVDMaestro that I need to install in order to get this work. Don't want to have to encode the whole movie to have to find out what isn't working. Everything else works fine, think I'm gonna love this.
why do you encode with DVDmaestro? I have the same problem with maestro but I don't really need that fuction because I use CCE to encoding... I hope somebody can help you...Originally Posted by Bullworth
Zzzzzzzz -
install cinemaster 2000
cinemaster 1.5 (the latest) will not work . but you can have both install same time ..
do a bit off a search and you will find cinemaster 2000
after that you will have real time preview ..
cinemaster 2000 is also found on some elsa driver disks called elsa dvd player of something .. not sure ..
i never accually got cinemaster to accually play a dvd on win2k server or XP ... and i didnt even bother to finish the install (after install at first time you insert a dvd it comes up with lic agreement and i hit cancel ) as it seems to mess it up when it sets its settings ..
doesnt mater -- it works with Maestro ..
the maestro installation cd you got when you bought it also has cinemaster player on there -- but unless your running nt4 dont bother ..
i would suggest to de-install windvd/ power dvd first .. install cinemaster 2000 , then install cinemaster 1.5 (if you want - it works very well acually) - , mainconcept encoder (if used) , then install powerdvd or windvd , then ligos codec last (if needed, which i do for anther app) ... -
I don't want to encode with DVDMaestro, I want to have the ability of realtime previews. Reading over my post I guess that's what it reads like. Well, BJ_M already answered my question, it works now, thanks!
FOL furious with McAfree ap that auto loads with either Flash, Java or..
By edDV in forum Newbie / General discussionsReplies: 0Last Post: 6th Sep 2011, 23:02 -
Firefox only loads google
By Squid_uk in forum ComputerReplies: 11Last Post: 5th Aug 2010, 15:51 -
Player which Automatically Loads SRT
By aphirst in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2008, 17:17 -
no video_ts just loads of rar files, what do i do?
By andrew101 in forum Video ConversionReplies: 8Last Post: 10th Nov 2007, 23:44 -
Loads of problems converting avi etc. to dvd please help!!
By mrd2007 in forum Video ConversionReplies: 9Last Post: 14th Jul 2007, 12:53
