Hi. I am trying to convert the Snow White DVD to XVCD using tmpgenc. This is my first animated film conversion and I am not sure what settings to use. I tried the way I normally do it but its all choppy. Do I need to apply one of the deinterlacing filters? Any help would be much appreciated! Thanks.
i did this movie, but to SVCD.....this seems to be a hybrid movie, switching from interlaced to progressive frames continuously... however, the video type is 99% FILM...
so i don't think you would have any problem forcing film in dvd2avi and encoding as 23.976 fps + 3:2 pulldown (i'm not sure if xVCD supports this, but this is wut i did for SVCD).
yes, try using double (adaptive) or blend (adaptive) de-interlace filter depending on which version of tmpgenc you have. the lines should go away.
tsMuxer for Snow Leopard
By jangai in forum MacReplies: 16Last Post: 22nd Dec 2012, 19:09 -
Samsung vp-w70 HI8 problem(white snow) - solution needed!
By 850nm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Jun 2010, 22:07 -
Baltimore Snow pics
By zzyzzx in forum Off topicReplies: 11Last Post: 22nd Dec 2009, 23:56 -
General call - Snow White (Disney) and Laserdisc
By darkbluesky in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2009, 10:39
