Just installed my spanking new DVD Burner (Sony DRU500A) and I was able to burn my first DVD+R which worked fine on my DVD stand alone player. So this tells me the drive is installed correctly. Then I went to use Nero to try to burn a CD-R disk and all Nero wanted to do was write an image file to the hard disk. Finally I found a choice under tools to 'Detect Recording Devices' or something similar to this, and it just couldn't find the DRU500A. It displays the unit properly text wise (i.e. f drive = Sony DRU500A) but when I go to verify it, it fails and says something to the effect "The parameters selected for this unit don't match please go back and change then try to re-verify". Well when I go back I can't change anything, theres only one option for every pick? Any ideas or advice would be appreciated. Thanks.
rhuala
Nero 5.5.9.14 isn't supposed to work with the new Sony. There's supposedly a leaked 5.5.9.16 that will, but I can't find it. Anyone?
Sony Vegas problem
By francisco-drm in forum Authoring (DVD)Replies: 1Last Post: 18th Nov 2011, 06:16 -
Problem with Sony Vegas
By Beibin in forum EditingReplies: 4Last Post: 20th Jul 2010, 21:28 -
Problem with Sony Handycam!!
By FrontierGander in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Aug 2009, 21:23 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 21:43 -
Problem with Sony Vegas 7
By DeaDudeA in forum EditingReplies: 6Last Post: 26th Jul 2007, 20:42
