Hi,
I have a PCTV rage and it works really fine with VDUB. Instead of the pinnacle WDM drivers (which does not support all resolutions) I use the 'generic' conexant WDM driver by Illusion Hope which really works great BUT: there is no way to select the tv channel for capturing in VDUB (except manually of course in 'capture mode - video source').
Is there a way in Win 2k with WDM drivers to select the TV channel before starting VDUB? or maybe within vdub? I'd like to do timer triggered capturing with VDUB but without beeing able to select the channel for recording it doesn't make much sense.
Greets,
MigueliTo
Launch your tv-application and select the channel you want to capture from. Exit your tv application. Open VD and start capturing
This is the last day of the rest of your life -
Hi Keitaro,
thanks for your reply. Already tried it, but did not work. Starting VD and entering the capture mode the channel is always set to the same - driver default? - channel. It seems to be a WDM-driver 'feature'
I heared that in Win 98/ME with the other driver model (VfW or whatever) it works like you explained..
Thx anyway,
MigueliTo
BtW I use the 'TV-Station' (Globe-TV, KNC-ONE) TV Software because the pinnacle Software/WDM-drivers collide with the generic conexant WDM-driver. Any suggestions regarding a TV appl which works via WDM drivers? And which maybe sets the channel in a way the driver keeps it until VD ist started..? -
give cyberlink power director 2.5 a whirl to easy to believe
How to select audio channel when converting MKV files ?
By vcd_user in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 17:48 -
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 19:03 -
WDM Driver programming questions
By cybertheque in forum ProgrammingReplies: 0Last Post: 8th Nov 2008, 19:14 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 14:53
