  1. Hi
    I will make a PhotoCD VCD with my jpeg's in which i could make different features. I've already looked at the Autor-Side about the help for PhotoCD's "How to make a VCD Photoalbum..". But not found what i am looking for. I've installed all this software and tried, but i haven't found the software in which i could make this:
    1. Various time for looking the jpeg's. 1 picture perhaps 5 second, the next one perhaps only 1 seconds, ...
    2. Various effect's for the jpeg's -mean's various transition (like in XAT.Show)
    3. Insert text for the jpeg's
    4. Menus and an overview for the pictures. So 1 maldives, 2 usa. And then an overview about the pictures maldives or usa.
    5. Sound
    6. A good qualitiy
    Something of this profiles i've in WinOnCd - but not all. On the Pc i could make all this for example in Power-Point. But for a VCD or DVD i don't know the software which could make this. Does anyone know in which software i could make this or have you an other good idea. Tanks.
    By
    Coco1
    2. Real photo vcds(high resolutions 704x480/576 still pictures) do not support any kind of transitions, if you want transistions you must make a a vcd/svcd video.
  3. errata: that would be 704x480/576 images...
    I highly recommend that you use VCDEasy / MJPEG Tools to encode your MPEG Stills.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. Hi
    I found something which has all this features:
    It's "Magix Pictures to CD & DVD"! Looks great!
    Here's the link: www.magix.com
    By
    Coco1
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep it looks good, kinda similiar to winoncd but with some more photo features. No demo though, let me know how it works if you get it.
  6. They now have free demo downloads. Check out: http://usa.magix.com/index.php?id=4656
    Thank You Kindly,
    LuckyLu
  7. Member twodogs's Avatar
    Dec 2002
    Australia
    Photodex ProShow will do most of what you need.
    Outputs to MPEG2, XSVCD, CVD as well as other formats.
    "speed's just a question of money. How fast can you go?" - Mad Max, 1979
    Mar 2001
    Antwerp - Belgium (Europe
    Don't forget that VCDwizard also creates STILL's (optimized mjpeg-code : inside of VCDwizard !)
