Results 1 to 13 of 13
  1. I have just bought a Pioneer A04 and intend to convert my miniDV tapes to DVD. I would like some feedback on what bitrates people use (CBR or VBR), and hence the length of video they can get on a DVDR 4.7Gb. I want to convert my tapes with no noticible loss in quality. 90 minutes per DVD would be nice but not essential.
    Thanks for your participation.
  2. I normally use VBR 6000 average - 8000 Max. You could use a lower average without much visible loss of quality. The best thing to do is to experiment on a short clip, encoding it at different bitrates until you find the bitrate that suites you.
  3. If these are home video's made using a handheld camera then they are notriously difficult for mpeg-encoders to handle well due to camera shake. However, as ItsMe said, an average of 6000 and max of 8000 using Tmpgenc 2-pass VBR will get you 90mins on a DVD. Going above 6000 will probably not see much improvement.
  4. Camera shake is indeed a big problem for mpeg, using a tripod whenever possible makes a world of difference though.
  5. Member DJRumpy's Avatar
    Dallas, Texas
    I wonder how many dual layer DVD's the Blair Witch Project comes bundled on?
    Impossible to see the future is. The Dark Side clouds everything...
    Upstate NY
    Loss of visiually perceptible quality is a subjective matter and depends alot on how you are viewing the final materal. Light pre-processing to take the DV-edge off of the video can do wonders for it's compressability. When viewed on a standard TV you would probably be unable to tell the difference.
    AVISynth and VDub can be used for pre-filtering.
  7. I am using the Sony pc100 and the pinnacle dv500 DVD. To edit the movie i use premiere. From the timeline in premiere i frameserve to cce 2.5. Setting are AVG 2500 Min 0 Max 5500 Multipass 3 times.
    So then we have a mpv file and a wav file. The wav file is converted to a ac3 file with sonic foundry soft encode.
    With this settings i can have about 3 hrs of movie with Dolby Digital sound (upto 5.1) and the picture quality is perfect.
  8. What about the resolution of input and output? Also other filters? Does it have any influence? What do you set?
  9. The input resolution and output resolution are the same PAL 720x576.
    Only the image quality setting can make a differance in the file size, normale i use a setting of 5. Other setting i use are.
    under the video tab.
    Add sequence end code
    upper field first
    Zigzag scanning order
    DVD compliant
    Other settings are not used.
    Hope this helpes.
  10. When putting together the DVD of my daughter's first year, I found that 6.25Mbps, which fits 1 1/2 hours / DVD, was excellent quality when encoded with CCE 2.64 from interlaced DV. I used VBR (6.25Mbps avg), and left the default noise reduction on. I have read that zig-zag scan order is for progressive frames, and that the linear quantization is for MPEG-1, so I left those off.
    I found that the same bitrate using the 2-pass VBR of TMPGEnc was not as good. It left some "pulsing" in static images that I think were occurring at the I-pictures, and there was some visible mosquito noise.
    Unfortunately, everything I tried in the area of noise reduction was a bust. If I reduced the noise enough to have an effect, it caused degradation of the picture. Spatial noise reduction decreased the detail, while temporal noise reduction ended up with ghosting and streaking. I re-encoded the video at least two dozen times with various filters, and the above approach was really the best I could get.
    This year I'm trying to use the progressive scan feature of the camcorder. Hopefully this will give me better quality when I make the second year DVD
    Xesdeeni
    Aug 2002
    I normally use CBR 8000 kbit/s and the resolution 704x576 with 16 pixels black borders on all sides (generated from FitCD). Then I can fit 1 hour without problems on a DVD-R.
    If I need more play time I use VBR but with minimum 6000 kbit/s average and 8000 kbit/s maximum. For best results I use Canopus Procoder inmastering quality. I also use avisynth preprosessing with the Convolution3D filter. If the video is shaky I use DynaPel Steadyhand to stabilize the picture. I do the editing after DynaPel Steadyhand and I edit in MediaStudio Pro.
    It is also possible to use the 352x576 resolution with average 3000 kbit/s if you can accept "almost VHS"-like quality on the output.
    I do not deinterlace! I encode interlaced with bottom field first.
    Ronny
    Oct 2002
    Contrary to popular belief, the Apple MPEG-2 codec is outstanding - especially when DV is source. I've done 720x576(PAL) at CBR2500 and had crisp, ultra-sharp MPEG-2, and it took about twice the movielength (a ten minute clip encoded in almost exactly 20 minutes). I know most of you don't use Mac, but... that's your loss
    "I have not failed. I have only learned what does not work."
    -Edison
    Upstate NY
    CBR 8000 is a waste of bits for all but the most demanding sources. Just use a CQ or CCE once pass VBR Q=10 you will get more space and virtually no loss of quality. I also find that avisynth TemporalSoften(1,3,6) works well for steady scenes without bluring motion. I don't blacken my borders since my HDTV has less than 5% overscan.
    Cheers
