I am using a Geforce4 a170 card and when I installed it card worked fine capture nice pics with minimal frame drops from my cam corder. I wanted to start ripping old VHS and hooked up my VCR. When I did this a white band appeared on the screen I was able to get rid of that by rolling back the drivers to Nvida WDM 1.08 drivers and here is where the headache begun. The picture that is streaming thru appears to be off centre the top is gone but there are lines f moving dots the capture is really blurry and square.
I have uninstalled it (WDM 1.08) in a vain attempt to at the very least keep capturing thru my camcorder but unsuccessfully. I can't get it to capture properly. I beleive it is the WDM drivers problem can anybody help me or if you have experienced this problem before using this card or similar as this is really annoying and not letting what was a great hobby into a pigs breakfast![]()
Results 1 to 1 of 1
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 16:09 -
Problem with the monitor: showing only white screen
By 1234567 in forum ComputerReplies: 0Last Post: 8th Aug 2010, 13:26 -
LCD only has white screen with sound.
By tj1182 in forum DVB / IPTVReplies: 1Last Post: 20th Jan 2010, 20:21 -
Screen becomes white after joining video
By venus in forum MacReplies: 3Last Post: 29th Mar 2008, 11:22 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 03:20
