Hi,
I have been using m2 edit without problem for a while, but now when i try to cut a vbr svcd from tmpgenc i of about 1.4 gb I end up with 2 files both 1.1 gb, what is going on here???
thanks estariol
Perhaps your earlier editing was for mpeg1 video ? M2-edit does ok for mpeg1.
However, for mpeg2 the multiplexing that it does is atrocious because the filesizes can end up nearly twice the size of the original. Luckily, it's not something that can't be fixed. Simply, demultiplex the mpg file into a m2v video and a mpa audio file, and then remultiplex with another tool such as bbMpeg. After remultiplexing, things will be back to normal. I have to do this all the time after editing mpeg2 with m2-edit. Just be sure to have the extra disk space needed.
Problem subtitle edit with MKV & MP4
By whitebeard in forum SubtitleReplies: 2Last Post: 19th Jun 2011, 08:45 -
Vegas Problem! Can' edit .mov anymore!
By duderdude2 in forum EditingReplies: 2Last Post: 18th Jun 2010, 04:39 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09 -
ac3 edit and remux problem
By maxWsax in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2008, 02:50 -
MAGIX Movie Edit Pro 12 problem
By Rein Engel in forum EditingReplies: 0Last Post: 21st Sep 2007, 13:40
