  1. I am having trouble converting DivX50 to Mpeg. ny files I have are rejected by Nero and TMPGEnc. Anyone help please?????
    If a codec is required then where do I get it
    Sep 2000
    AussieLand (Down Under)
    easy way
    1stly, divx5 blows goats.. nextly, the simplest say (althou it might be bigger) convert your file to another format in vdub.. say get a mpeg encoder and do it that way.. else stream copy to PICVIDEO or huffyUV and then tmpgenc that.. simple??
    hard way
    uninstall taht divx 5 rubbish. install 4.12, and get all yoru drivers in order. re-capture and then you can serve to tmpgenc.. i think.. i have before..
    Damn TLA's, they confuse everyone.
  3. Thank you my friend, it's done
