What will I need to split a big movie (>4.3 g) into 2 dvd r's??
thanks
U could use ifo edit, lok at the guides on doom9.net but if the is is only 4.3 U could use dvddecryptor to make an image & burn it back to a single dvdr. If the movie is just 4.3 gig can do a similar mothod by ripping only the move & then create new ifo removing the ectra languages & subs in ifoedit then burn with either nero/vob writing software.
Kev! -
If he's on mac (he posted in Mac Video Forum) then he'll have to use Virtual PC to run IFOedit. IFOEdit works in VPC, but it is very very slow doing it that way.
Go here for a guide and software to do what you want on a Mac: http://www.anycities.com/user/bilestyle/index.html -
I tried using ifoedit in virtual pc with the guides in doom9 but when I burned it using toast my dvd player couldnt read the disc. I dont know what Im doing wrong and I was hoping there was a way to split in using just mac programs. Is there? Thanks
Yes. Goto the link I posted above.
Also here: http://www.volcanowd.com/sites/DVD/Guide.htm
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 05:25 -
Help! Splitting a DVD
By StrikerZERO in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2008, 20:19 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 12:17 -
Splitting episode dvd to 2 discs
By parman in forum EditingReplies: 3Last Post: 12th Sep 2007, 17:05 -
Splitting VOBs for burning to DVD ?
By paulwilko in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 04:37
