My question is will both pal and ntsc playback on the same burnt cd?
Or do I have to keep them seperate?
If your DVD player supports both, yes. You will have to switch between the modes accordingly though.
I don't know about Nero, but you can definitely burn both PAL and NTSC material on the same VCD. I've done so myself on several occasions and it is in the PAL/NTSC Demo VCDs here: http://www.vcdimager.org/discs.phtml#demo
Depending on your VCD/DVD player and TV, you may or may not need to manually switch between "PAL" and "NTSC" settings on your hardware.
Regards.Michael Tam
w: Morsels of Evidence -
My player (well I have 2), but the one in my computer room is a cheap ol' apex ad-1200, it has an option to auto-detect pal/ntsc... Would that be the way to go..
I know Just test it myself, lol-- just wondering what other people have encountered.. -
It depends on your player + TV...
Both my players have "auto PAL/NTSC" and all this means is that if it detects PAL video, it outputs PAL video signal and if it detects NTSC, ditto.
Alternatively, I can hard set it to display PAL or NTSC (and it will do the relevant conversion as necessary in real time).
It then depends on your TV. On one of the TVs, it can auto detect PAL and NTSC as well and display it properly (i.e., multisystems TV). Thus, this works great with the player.
On my other TV, it is PAL only. So, if I put in a disc with NTSC content (and the player swtiches over the NTSC mode) I end up with B/W video. Setting the player to "PAL" rather than "auto" (i.e., so the player does NTSC --> PAL conversion) makes the picture display properly on this TV.
Regards.Michael Tam
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
At What Stage Do I Convert NTSC DV to Burn PAL DVD?
By Dubinvero in forum Video ConversionReplies: 4Last Post: 5th Oct 2010, 18:03 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
