I am using a cd-rw to test my (S)VCD's on my standalone player before burning them on a cd-r..
How many times can I erase my cd and start over before I start losing quality?
Also, should I use full erase or fast erase (NERO)..
Full erase takes 20 minutes, fast erase takes 2 minutes, lol..
Any input would be helpfull
BTW the Medium is a Memorex Platinum Rewrite (low speed 4X)
You should be able to erase the CD-RW with quick erase as many times as the CD-RW says it will last.
(IE, depends on the brand...just burn away!! Keep up the testing on RWs, it saves discs!)Tom Green Sucks! -
I'd suggest 100 times (my opinion).
It is always better to do a full erase (fast erase MIGHT leave some bad sectors) - otherwise there wouldn't be an option, would there? -
Originally Posted by 0 kewl
As for lifetime of CDRW's, I believe they should last at least 1000 erase-write cycles. -
I know I've had problems with the Memorex 4X RW's
Out of a 25 spindle, I had 4 that wouldn't rewrite the first time, and 3 more that started giving me that problem after about 3 cycles.
I tried full erase w/ Nero and CloneCD, I tried leaving them out in the sun...
I guess I know now not to buy their crappy discs againwhat are you askin' me for...
I'm an idiot!
DVP5960 and other players: test files
By Squash in forum DVD & Blu-ray PlayersReplies: 7Last Post: 1st May 2011, 19:49 -
Test .sup files?
By Charmer in forum SubtitleReplies: 13Last Post: 14th Sep 2010, 23:16 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Batch Test AVISynth (avs) files
By tevert in forum Video ConversionReplies: 9Last Post: 2nd Apr 2010, 10:38 -
How to test MPG files for errors?
By madmartian in forum Software PlayingReplies: 1Last Post: 17th Jun 2009, 14:30
