  1. HI -
    I can't seem to get batch encodeing to work right. I have added 6 projects to the batch, and then I start the batch. It encodes the first file but then instead of continuing on with the next file in the batch, it just exits the program
    What am I doing wrong ??
    LG
  2. For some versions you need to download a specific VFAPI plug-in to do a batch encode. You can check if you already have this plug-in by going to Option->Environmental Setting...->VFAPI plug-in. The plug-in you need is TMPGEnc Project File Reader 2.xx (depending on your version).
  3. Mmmmm yes I have it there ... with a priority of 0. Should I increase that ?
    LG
  4. You can try but i don't know if that will help since mine is set on -2 and it does batch encoding perfectly. The only 3 things i can think of are:
    1) The second file was unsupported by TMPGEnc (or needs different plug-in settings like for XviD)
    2) The input file(s) (audio and/or video) were moved to another location or deleted
    3) The output file's name was the same as for the first output file (although this is not that likely since TMPGEnc would, i think, ask whether you want to re-write the existing file).
