Hi,
I'd like to know how InstantCD/DVD is.
I heard it supports VideoCD and SVCD.
Anyone has and uses it, please.....
Chjan
Yes it does support VideoCD and SVCD but it's very basic. It doesn't create menus or anything like that. If all you want is a basic VCD or SVCD that plays from beginning to end then it's fine. If you want discs with menus ec. then you will need to create the layout in another program, create a disc image, and then burn it using Instant CD/DVD. Of course this rather defeats the purpose ef you also have Nero or Easy CD Creator as you can also use that app to do the burning.
