OK, this is a little off topic for this site, but I'll bet someone here knows the answer. What's going to give me the best combo of small size/quality for making video files to play on a Pocket PC? Anyone have any experience with this?
The answer is quite obvious. Divx is a better choice. Here are my reasons:
1) Divx yields better results with same bit rate
2) with Divx, you can select any resolution you want. For example 200x120, 300x160, etc... therefore you can choose whatever you like to fit the screen. At smaller resolution, you can also select lower bit rate for encoding, thus results in smaller video file size.ktnwin - PATIENCE
playing looped video clip from pocket projector
By josefin in forum Portable VideoReplies: 1Last Post: 25th Jan 2011, 19:53 -
Help please, easy format pocket camcorder?
By Lilygrace in forum Newbie / General discussionsReplies: 14Last Post: 23rd Aug 2010, 13:04 -
safe few bucks from my pocket
By mrdin2005 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Jul 2009, 05:26 -
Fujitsu Siemens Pocket LOOX
By mgowins in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 17:09 -
Movie player for Pocket PC??
By Cazz in forum Software PlayingReplies: 2Last Post: 2nd Jul 2009, 16:39
