I have seen guides for the video portion of an mpeg/VCD/avi etc...
but I have not seen nor been able to find one on enhancing the
quality of the audio portion of an avi. I know about all of the tools
and how to use them, I have before, but never to do this.
Any ideas or links for more info?
Thanks![]()
Guest
Panasonic DMR-ES45VS, keep those discs a burnin'
Guest
Thank You Kitty! I was still searching and found this post at just about
the same time you did. (Duh on my part). (BTW: I really like the links
on the site you have listed in your sig).
If I could ask, I do have another question:
I have several avi's that are apparently NOT stereo. The audio only
comes out of one speaker. The audio also has a "AM Radio" sound to it.
Since I am not working with the original recording is there anyway to
change the audio to at least sound half way decent?
Thanks again!
Enhancing Audio Volume in Video
By redevil01 in forum EditingReplies: 4Last Post: 29th Oct 2021, 11:00 -
Enhancing a still from video
By jackhandsome in forum RestorationReplies: 58Last Post: 24th Oct 2018, 19:56 -
How to save Re:Quality guide for HTPC, how to configure MPC-HC, ffdshow, et
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2011, 09:09 -
StaxRip Guide-w-Templates for High Quality XviDs
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 02:53 -
Enhancing video detail/quality
By azinkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jun 2007, 09:16
