Results 1 to 10 of 10
  1. trying to put vcds onto dvd
    used tpmg to multiplex audio/video
    changed audio from 44 to 48 as in guide
    renamed both files
    ie mpa and m1v
    but in stored folder it shows theseas both mpeg files?
    can import m1v ok but audio wont import tried to import audio first to be told i couldnt so spruce knows there is an audio file still wont import tho.
    win xp operating system
  2. Member wulf109's Avatar
    Jul 2002
    Try renameing your audio .mp2 file to .ac3,this has worked for me converting SVCD to DVD.
  3. actually i tihink you have to rername it as a .mpa this is also an mpeg audio form that should work
  4. Member wulf109's Avatar
    Jul 2002
    Renameing the audio file to .ac3 will work. You could also use Mpeg Tools to remux you .m1v and 48000 audio file into an .mpg which SpruseUp will also import.
    Dec 2001
    South of Sydney. Aus
    When I have used SpruceUp (with mpeg2 files), I had to name the video & audio file the same eg test.m2v & test.ac3. Spruce would load the m2v file first then go looking for a like named ac3 file, then load the sound file automatically. Though you are using mpeg1 files, this may work for you
  6. ve tried all, of theseand it still wont do it
  7. Member wulf109's Avatar
    Jul 2002
    Superleeds
    Has your trial period expired??? All the mentioned options work.
  8. DO NOT LINK TO WAREZ!
    TGPO
  9. i have tried all of these and dont get any audio files when i rename my audio file the properties still tell me its a mpeg file
  10. Member wulf109's Avatar
    Jul 2002
    Changing the file extension to .ac3 does not change the files properties,it's still an mpeg audio file. Changeing the extension simply allows Spruce to import it. You should have an .m1v and an .ac3 file. they should be in the same directory. They should use the same file name,for example test.m1v and test.ac3
    Is that wha your doing?
