how can i tell if a video i have is either of these?
thanks,
It'd be difficult to be exactly sure just by looking at it.
If you've got the file on your PC you could easily check by loading it in something like TMPGE, but it seems that isn't the case. You could always rip the file off the cd in question and check it out as well.
If you're talking about a file you just downloaded as an mpeg, it's most likely in VCD format.
...You need to give more information. -
i do have the video on my hd. that's the thing. it's almost great quality and it has "vcd-xvcd" in the name and dont know which it is...
<font size=-1>[ This Message was edited by: MAIOF on 2001-08-21 17:05:42 ]</font> -
someone please? i still need help trying to figure out if a video i have on my hd is vcd or xvcd because in the name is "vcd-xvcd"
thanks much,
maiof
<font size=-1>[ This Message was edited by: MAIOF on 2001-08-23 18:13:11 ]</font> -
Load it into TMPGE and check to see what the specs are. If they aren't standard vcd (you can check that by loading the VCD template to see what they are if you aren't sure), then it's xvcd.
But if it's labelled "vcd-xvcd" I'd bet that it IS xvcd. -
Load it TMPGEnc and pull it up in the de-multiplex dialog. If the video stream in the file is MPEG1, 1150 CBR, it's videoCD. Any other bitrate and its xVCD. MPEG2 and it SVCD or not a standard format at all.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
